choppinczech
Man you're making quick work of this. It'll be on the road in no time.
How's the ease of registration and titling in your state?
You are correct about space being scarce in these things. I spent a LOT of time designing and modifying to gain fractions of an inch, here and there, in the process of trying to utilize every millimeter. I’m a 6’, 200+ lb man... not much space in my standard bob tail bucket... especially with three petals and a shifter to contend with. Big go carts!At the same time I glued and fiberglassed in the plywood seat riser support and closed off the area around the driveshaft. A piece of 3/4 inch plywood is screwed and glued on top of this frame and the rails for the seats are bolted to it. I am going to use the bucket seats from the Ranger as they are in good shape, seem to fit in the bucket nicely and are quite comfortable.
The two holes you see in the pics of the floor are to bolt the bucket to the frame. I will use these bolts to fasten the seat belts to as well. I cut a couple of slots in the front of the seat riser to make it easier to get at the bolts and use the under seat area for storage. Not much room in a T to put stuff so any amount is useful.
View attachment 18638 View attachment 18639
Make sure that you plan for insulation on the passenger's side floor. A few years ago, I got badly burned, on my feet, in a bucket, where the owner routed his exhaust similar to yours!
