fletcherson
I can’t think of a better way to do it. Good job! Hope It doesn’t do funny things as it cures... I learned that one the hard way, like most things in life.
Outstanding! Can you extend the cowl's body lines into it a foot or so? That'd make it really blend.
I had the same thought but didn’t want to sound judgmental. Even a tip of the arrow or similar to tie it in. Could also smooth the contour off of the cab to achieve a smooth look. Just brainstorming... looks good as is. It would add rigidity.Outstanding! Can you extend the cowl's body lines into it a foot or so? That'd make it really blend.
You are the only person it has to please! Looks good.Thanks for the ideas guys, but I do not know if I want to mess with it any more.![]()
I have a fiberglass 32 hood which is too wide for my 23 t. I plan to cut pie slice shaped pieces out of the hood's top.
Unique battery location. The engine choice affords space not available to most.The Speedway frame came with the mount for the brake master cylinder in the floor. This was not going to work for me as it was in the wrong place to allow enough room for the clutch pedal so I ordered the hanging pedal assembly. This allows the brake and clutch master cylinder to be mounted on the firewall.
At this time I made the brackets under the cowl to hold the steering column and made up a steering shaft with two universal joints to connect the steering column to the Vega steering box that came with the frame.
View attachment 18768 View attachment 18769
Alternator bearings live a rough life anyways with the heat generated. A little water and time to rust likely done em in. Easy, cheap fix.For some reason the Ranger alternator decided to seize up just sitting in my shop. Perhaps cleaning the engine at the car wash did it in I dunno, but now I needed a new one. A friend had one that was working from an old Honda car and donated it to the cause, so I made up a new mount for it and bolted it on. Measured what I thought was going to be the right length belt and ordered one from Rock Auto.
. . . . build thread on my latest Model T. Note that most of what I am posting is awhile after the fact.
