IT'S ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 3.5 years and countless hours later
So after 4 days of fighting with wiring and cursing Murphy, I got it going with a couple small hiccups.
First start took a bit with the mechanical fuel pump to prime the system. I had the timing close enough that it started once it got fuel.
Then the secondary system started puking fuel through the vent, seems the float was missing the small clip that holds it in place, well it slipped off the set post and well gas was every where. That was a quick fix once I pulled the bowl off.
So it was running for about 5 minutes, spit out some fuel through the primary vent tube and died. So thinking that something similar went wrong with the float I started troubleshooting. Which brings me to the lesson of the day
"Before troubleshooting a "bad" carb........check the gas tank", yup I ran it out of gas.....dumb ass move and 15 minutes of tinkering before it dawned on me to check the tank.
My biggest concern was the transmission, since I rebuilt it myself I was sort of expecting the worst, but it shifted into all the gears, and moved 5 feet forward and in reverse. The break in headers did not allow the wheels to turn very far. Well that and I still have to make the gas pedal
So now the engine and cam is broke in, the carb is adjusted and once I make a gas pedal I will take it for a spin.
Only outstanding items are:
Tail lights.
Front turn signals.
Windshield.
I cannot stop grinning
