Since it tends to snow here on the North Coast, I've made a list of things to do to my T (which I bought used this spring) this winter:
-Pull motor, replace dented oil pan and leaky gasket
-Redo fuel lines (replace rubber with steel)
-Replace cracked windshield
-Install side view mirrors
-Remove engine fan, mount electric fan (with thermostat) on the back of the radiator
-Change headlights
-Clean up wiring
-Relocate ignition and headlight switches to more accessible location (currently on the front of the seat)
-Paint new headlight buckets and air cleaner (body color)
I PROMISE I'll post pictures and you'll probably see a few questions and requests for advice as the work progresses. Hopefully I'll get most of this done by spring!
-Kevin
-Change headlights
-Clean up wiring
-Kevin
