That is a fact, I have a build binder going that I have those plastic document sleeves in. When the time comes I will just photo copy them and attach to application. I also plan to print "during" the build pics so I have a coffee table book of sorts to reminisce my aggravation lol. Also I believe the State po po will verify your engine & tranny serial #s to make sure they ain't hot. If you don't have a receipt for them be prepared to explain where they came from. They may be ok with if you had them for several years, not sure. I have been reading the crap out of every post I see on forums relating to PA titles, and any negative experiences. Not sure if you saw this, not from here but a checklist of sortsI've heard they will make you show receipts on what you bought to prove you paid taxes.
I got a 5.3 LS motor out of a truck, purchased a new block from Summit, good luck tracing this engineShould be interesting. My engine is out of a car I still own. The trans is a junk yard find with no receipt. Hope I don't run into problems.
OK is OK lol, PA sucks to build a rod.......I was in Enid once for a few weeks when I was active duty (actually got some good Chinese food there, who'da thunk in the middle of nowhere), anywhere near there? My bro lived in Shawnee for a whileIn Okieland all I ever had to show was an itemized list of what I used to build with, along with a price. Frame showed as home built. I had engine and trans numbers. I did have to show speedometer with odometer on the list. I always made a speed sheet with all the info on it. Takes about 30 minutes to get paper work for title once they wait on you. Done this on several car builds, and lots of motorcycle builds. Sometimes I think its to easy, almost scary.
Perhaps this copy from the NSRA Safety Inspection Rules will help explain "scrub line".I'm in PA also, near as I can tell from all my reading of PA inspection laws & questions, if you run a string diagonally from the bottom of the rear wheel to the bottom of the opposite front wheel and same for other side that is your scrub line. It's all about if you get a flat theoretically the wheel will stop anything from scrubbing. PA SUCKS lol
Thanks Jim, I was going off the noggin when I explained. It is in fact wheel to road surface, not wheel to wheel. Your pics do reflect PA law:
The problem with most online purchases is that they do not charge tax. That's all great...until you have to prove you paid taxes...
In some states , any purchaces made out of state that does not have a reciprocal [sp.]agreement , you will be taxed on those purchases at the time of registration
Zandoz - no yearly tax on vehicles in PA. Just the upfront taxes at the time of purchase or in this case, at the time of titling. Annual registration for a car is thirty some dollars, eighty something for a truck. I have no idea what it is for street rod. Shouldn't be much.
