I do. I’m opting for a bigger one anyway as I believe It may be leading to my third issue but I figured out the first two. The turn signal had a looses connection inside the headlight bucket. The horn, well, I took apart the weatherpack to feed it through the floor and put the wires back in all 1 wire off.Do you have your engine grounded to the frame ? If not ; you need an engine ground cable.
