I know, I tried to insert the link to Amazon and no dice.I think Weatherpack connectors only go up to 6 pins, and then jumps up to the 22 pin bulkhead connector that I used for the firewall. I haven't come across any other brands that make anything over 6 pin connectors either. It would be nice to have one for my gauge panel. By the way PotvinGuy, your last reply looks empty on my end.
Those are nice too. I'm going to have few connections, basically the lights and maybe the engine, but my wiring will all be in the body, under the seat, under the dash, and the wires will be inside of the rockers. I want to be able to unplug and remove the tub, but most of it will be in it. That is if everything goes as planned. I am gonna update my crimpers for the GM weatherpack style. I saw a nice ratchet type on Amazon for $25.00 or so. I'm not to that point on my build yet.I'm considering these guys, when I get to that point Their paks also come with a pig tail, as an option for us guys lacking crimping skills or tools.
Weather Pack Assembled Pigtails - 6-Way
If it's a cast iron manifold, the bolt can be blown out with a torch, but I'd reccomend having an experienced person do it. I burn studs, bolts, etc out of heads and exhaust manifolds all the time, or used to when I worked on stuff more. The busted easy out is no fun. They are so hard and brittle. Was it a tapered square or a reverse threaded type? Its fixable, have patience. No fun, for sure.I tried welding a nut on the top but it kept busting off. I might try what you guys did though. The bolt is pretty small, 5/16" so I'm a little worried about accidentally welding the bolt to the intake. Then I might really be screwed lol.
