I have a new CCR 14" frame and setting tape and was thinking of Lexan instead of glass. Right now I'm using the CCR 11" frame and it is a bit too low for my giant head.If you are running a full frame around it, it will be ok. You could get a piece of 1/4 aluminum channel from a hardware store, such as ACE, and frame the top and bottom. Black RTV would hold it in place. I put a top frame on my glass windshield, just because I felt safer after seeing how much it bowed at speed. Lexan will bow also, but never break.
Lee
The seller is tooltymegirl. I bought it 1/4" thick.Cmcdanl, which seller on eBay did you use? What thickness?
Anyone, does 1/4" seem enough? I was thinking of 3/8".
This sounds like a good idea. Might even look ok too. I'll give it a shot and see.If you are running a full frame around it, it will be ok. You could get a piece of 1/4 aluminum channel from a hardware store, such as ACE, and frame the top and bottom. Black RTV would hold it in place. I put a top frame on my glass windshield, just because I felt safer after seeing how much it bowed at speed. Lexan will bow also, but never break.
Lee
I thought about that too. I bet it would look pretty cool. I decided against it for now, but who knows I may change my mind down the line.Hey, I see gray tinted MR10 on eBay too. That might look very cool. Not sure about legality, but I'm a rebel who never ever does what he should (group and year?).
Thanks! And yeah, that's not just the pictures. Once I peeled the protective plastic off I realized it's almost invisible! I bet once it's in the sunlight, and the car is painted, it will be more noticeable.That looks real nice. You can barely see it at a glance. Nice work!
a rebel 'cause he never ever does what he should (group and year?)
Nice job. TV on one wall, stools on the other. Where is the cooler for refreshments? Keep the pics coming.
