WOW !! I finished the passenger side windshield post today. I sanded the area with 80 grit sand paper. I laid the post against the body & marked around it with a sharpie. I masked off the area ( I left a 1/4' SPACE ) with black gorilla tape. I covered the inside & outside of the post with Vaseline. I also applied Vaseline to the corner area of the windshield frame & the 2 bolts. I spread the ," kitty hair " on the body. I quickly bolted the windshield post back in place. I had to spread , "kitty hair" on once more , I still had a few low spots. THIS WAS A PIECE OF CAKE !! Thanks butch27 & cooter , you guys were a great help. I'm going to have to remove my dashboard because most of the windshield frame is inside the car. It looks like custom dash time !! Whoopie !! I'll take some photos tomorrow.
The bottom horizontal piece of the windshield frame has about 1/8" of the frame actually resting on top of the cowl. I plan to space the dashboard 2"s from the windshield frame. It will be about 5"s tall.
  I did this post 3 times. The one in the photo is me second time. I haven't uncovered the 3rd attempt yet. The drivers side took 2 times. With each try , I add more kitty hair to fill in the low spots. The one posted here is from the passengers side. Tomorrow i'll remove the post & see what I have. If both post look good , i'll move on to welding my headlight brackets to the frame.
  Here are some  photos I promised to take today. This is the passenger side post , I removed the post 5 times & added kitty hair to the low spots. I finally got it right. Tomorrow i'll  remove the driver side post & see if it still needs more kitty hair. I'll take photos of that post tomorrow. I promise. I'll probably start working on the dash board next.
