Looking real nice there.Well I got my parts from Ron Saturday but I had to clean the garage out, put up new lights, wire for a 220 outlet and organize. So needles to say I didn't get anything done. I did however get a warm fuzzy feeling when I rolled it outside to do the task I mentioned. Had a couple neighbors stop by and take a look at it. Snowing and wind blowing 30mph today so not much happening in garage todayView attachment 10889 View attachment 10890 . :-(
Hey Ron I got the steering box bracket tack welded on. How much ground clearence do I need? As of right now I only have 2 1/2 inches. But I have the front in the lowest hole on batwings.Looking real nice there.
You need to raise the frame up some. 2 1/2" ain't quite enough.Hey Ron I got the steering box bracket tack welded on. How much ground clearence do I need? As of right now I only have 2 1/2 inches. But I have the front in the lowest hole on batwings.
3 1/2" will be close, but should work OKThe question is how much is enough. I want this car as low as I can get it. Is 3 1/2 enough? I think Exjunk has his oil pan down about 3 inches of clearance.
Amen to that, unfotunately, rust capital too.I have to admit that our roads here in Florida are much better than in a lot of other parts of the country. I moved from what I think of as the pothole capital of the country, Northeast Ohio.
I think I am going to shoot for 4 inches of clearance and roll it back outside and see what it looks like. When I put the spring on the front I actually went in the bottom hole of the batwings and dropped the ride height about one inch. So if I raise it up 1 1/2 inches it will only be a 1/2 higher than originally planned. The only thing that concerns me is how much the ride height will settle once it is finished. I have heard 1 inch is about the usual amount they settle. What have you guys noticed on this?
In this thread https://tbucketeers.com/threads/front-axle-suspension-questions.14528/ Resinator explains how to simulate the loaded height on the front end without actually putting in the motor, on cars with multi-leaf springs. I wish I knew some way or estimate for mono-leaf set ups. Since I do not have anything for the mono-leaf, for now I'm going with the shock manufacturer specified ride height.
For minimum ground clearance I've not used a single figure. I'm going by an imaginary line between bottom center of the front and rear rims. Absolutely nothing below that line.
could you switch to a corvair box on top of the frame? I was going to go that route, but with a bbc, it's crowded.UPS and FedEx both showed up at the same time. lol Got the headers, steering wheel and steering shaft. Radiator should be here tomorrow. Here is a couple pictures. Going to have to do something different with the steering box. I still could only muster 3"s of clearance after raising the spring to the top hole in the batwing. Frame is 9"s off the ground and yet that bracket is still way to low. Not sure what to do but will call Ron in the morning. He will help me figure it out. A close up shot shows the steering box clearly below the scrub line. The links I made to take the place of the rear shocks were short by one inch. I made overall length 12 3/8ths instead of center to center. Going to redo them tomorrow and make them adjustable as well. The back needs to come up one inch and that will put the headers right about parallel to the ground. Or if I can figure out a way to move up the steering box I will drop front down one hole on batwings.
View attachment 10910 View attachment 10911 View attachment 10912
