stretch
If there is any one tip I would give folks building CCR's chassis and using their stretched body, it is this: disregard the instructions, and lengthen the chassis! I have essentially no room between my electric fan and water pump hub. I couldn't run a supercharger if one fell from the sky and hit me on the head! which is probably the only way I'll ever get one...
So I am going to add probably 6" directly in front of the motor mounts. Not only will this make me less nervous about the fan falling into the water pump, it should improve the ride. Other than the metal needed for the stretch, everything else is pretty simple. Gonna replace all the brake lines anyways. Wiring isn't a problem. Already got the 7/8 tubing I need for the new longer drag link, and will hit the steel supply place Saturday for some 2X3X3/16 tubing, and some 3/16 plate to make insert tubing (probably 18" long) for plug welding the extension.
Got some other chassis work to do too. Bought a 700R4 to replace the TH350, need to move the tranny mount back, and shorten the driveshaft. Putting doors in, so can take the steps off. Once the chassis work is done, off it goes, along with other stuff I can't get in the oven, to a powdercoater.
New radial tires coming, new steering stuff (new, not junkyard), new interior (re-upholstering some '68 IHC Scout buckets), lots of other stuff. Gonna take me a few years to do all I want before she's back on the road.
More later.
Frank
More later.
Frank
