tfeverfred
Here ya go Paul.
PaulR said:Fred,
Thanks for the pic. Are you going to run the wires inside? I'll have to come on by and take a look at Miss Behavin.
Paul
Duke said:Fred, on the Lokar shifter, you need to adjust it just a little. Looking forward from the back, on the right side at the base, you will see the starter safty switch.. To adjust the safety switch there is two screws near the base that when loosened, you can move the switch plate to adjust the switch position. - On the left side - there is two screws at the bottom of the left side plate. This plate adjust the shifter locking points. It has some dedents on the inside of the plate that the shifter locks into. You need to adjust this plate just a little one way or the orther - and the button will pop up and lock the shifter in postition. Being as how you can get the button to pop up with a little bump to the shifter tells me you are real close and need to adjust the dedent plate just a hair. Hope this helps -
Mike said:Fred, I'm hoping you checked out the electrical specs on that disconnect switch carefully. It was sold under the Molten Lava or Roman Candle trade names, was it?I know what I have to pay for switches from my suppliers and a fiver isn't even close.
You better make sure of what you have there. We don't want to have to start calling you Smokey!![]()
all-world1 said:This is the first time I've read thru this thread, I like how you did the updates chronogically with a lot of good pics as well. It's a great build fred... a very clean looking chassis, well thought out. Your experiences will be a big help to us new builders. Two thumbs up.
tfeverfred said:....See, I don't have my car wired yet, so it's running off the battery. When I leave it hooked up, it drains it a little, so I installed this to keep from losing a little juice while just sitting.
tfeverfred said:...ELECTRICITY IS THE DEVIL!![]()
