Tmaxx, didn't mean to be a copy cat, but I do have to say you have a sharp looking rod. Do you have a posi rear end? If so, do you have any problems with it fish tailing when you bust into it? Mine is similar to yours - 350, Weiand 671, dual carbs, THM350, 2750 RPM Converter, 4.11 Rear Posi, putting out about 480 HP with 18" Mickey Thompsons on the rear. It is dyno tested at 400 ft/lbs at the rear. I can rip the rubber off of the tires at almost any speed, but when I step on it from a dead stop and those Mickey's start spinning, it is literally uncontrollable. Once I exceed the converter RPM's at about 3,000 or so, the T violently whips to the left. I know the car is light and the wheel span is short, but Man, Oh, Man. Any suggestions other than not bust into it?
