tfeverfred
O.K. Fred, the gauntlet has been has been thrown into the ring. What do you have to counter ?
I'm good.
Just kidding. How goes the battle in Houston ?
John
I'm good.
John
John, I agree 100% on incorporating a K member in the construction of the frame for the very reason that you stated. Under acceleration a simple "ladder" type frame will twist and the K member helps to cancel that out.I really love frames at this point of construction. I like the thought of a k member to stiffen the frame rails. They are so simple and honest. So much promise. Add an engine. Throw in a trans. Maybe add a body.
So much promise.
John
I've been pondering a k frame addition in mine to combat twist. Idk if I have room.I really love frames at this point of construction. I like the thought of a k member to stiffen the frame rails. They are so simple and honest. So much promise. Add an engine. Throw in a trans. Maybe add a body.
So much promise.
John
Fred, are FFW your initials ?
Thanks for the kind words Rubicon, means alot to me. I watched your build and I can only hope my car looks as good as yours! I can see you paid alot ofJust went through your thread from the beginning. Your work is impeccable. When someone is able to take rough materials and make something of quality out of it I'm amazed. This reminds me of the guy that built a copy of a Lamborghini in his basement. I have to buy most of my parts. Keep the pictures coming and thanks for sharing.
Now Jim, how often do you "get after it" in your car. I'll bet you baby that thing! Besides, your wife would probably slap you upside the head! Just kidding!John, I agree 100% on incorporating a K member in the construction of the frame for the very reason that you stated. Under acceleration a simple "ladder" type frame will twist and the K member helps to cancel that out.
John, my car is in the build stage, but the frame has already been built, and powder coated! I am not about to go grinding or welding on it now. I didn't really think about itDoes not have to be rectangular tubing. Can be round tube. Or oval tubing Ask Ex-Junk. Could be a bolt in K member incorporating a trans mount. Does not have to run to the back. Could be run towards the front.
Or a little bit of both - front & rear.
Can be oval tubing bent to clear.
Is the car in the build stage or in the built stage ?
My wife is with me on most outings. She really enjoys when I stand on it and lay some rubber as long as there is no traffic around.Now Jim, how often do you "get after it" in your car. I'll bet you baby that thing! Besides, your wife would probably slap you upside the head! Just kidding!
View attachment 14454 View attachment 14455 3 coats of Summit Moss green metalic and 2 coats of clear
Thanks Fred. I wanted green as the accent color, but not something too light or too bright. I think it came out pretty good.Nice! Great color!.
