Welcome to Our Community
Sign Up
Dismiss Notice
The Yeti's 27 T Build
Discussion in 'Project Plans & Updates' started by TheYeti, Dec 21, 2019.
  1. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    Thanks for the tip on the Pete and jakes bat wings.
    Being as the heim joint is spherical in nature it has no care what position it is used in as long as it doesn't bind. I'm fully aware that a binding heim joint could turn into a sheering situation but ive got WAY more free travel in this suspension system than this car is capable of using. I fail to see an issue with this setup.
    Kevinrevin likes this.
  2. Spanky
    Expand Collapse
    Jul 29, 2016
    3,015
    2,422
    Gender:
    Male
    You're making real progress, Chris.:thumbsup: I saw the discussion of your front end on the social media page and I can't say your arrangement is unsafe, though a bit unconventional. Only problem I see would be putting one end of the axle at a steep angle (like a steep driveway?) and binding the heim perhaps to the breaking point. But in normal driving I can't see a problem. If they were mounted vertical, in a batwing say, there would be no danger of binding.
    TheYeti likes this.
  3. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    Definitely making progress. Not as far along as I wanted to be. I wanted a rolling chassis by the end of this month... hope to have it driving by the fall.
  4. LongJohn
    LongJohn
    Expand Collapse
    May 10, 2022
    49
    30
    Gender:
    Male
    Only thing I have to say about the front axle is I would like to see the rods further apart. With only the width of the axle between them you won’t have as much resistance to roll forces when you apply braking forces. The bat wings would be a good fix plus you get the heim ends in a more traditional configuration.
  5. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,487
    745
    Gender:
    Male
    Occupation:
    Retired
    I agree with Long John. Very little moment arm with the small distance compared to 6"with the bat wings. I looked farther back and did see the spring shackles!
    TheYeti likes this.
  6. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,851
    770
    Gender:
    Male
    Occupation:
    Yeti, I think your front end will be just fine. How will you control lateral movement of the axle? Panhard, Watts, Rulo?
  7. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    Well that's something that was going to be a "cross the bridge when I get to it" kind of thing... There is very little to no 1/4 elip info that I have been able to find but from the input that I have found, they say you don't need a panhard with the 1/4 elip springs and side steer.
  8. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,716
    922
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    Speedway has info on the 1/4 elliptic setups.
    Maybe RPM has done some before.
    Give them a call.
  9. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    Don't know where the 1/4 elip info is on speedway.. I found steering articles and what not.. no 1/4 elip. Would you share a link?
  10. Spanky
    Expand Collapse
    Jul 29, 2016
    3,015
    2,422
    Gender:
    Male
  11. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,211
    1,181
    Gender:
    Male
    Occupation:
    Retired
    You need shackles in the axle. There will be no movement with the spring arch and the radius rods being different lengths.
  12. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    My neighbor has a '27 track T that he built using a body, frame, etc. from Zipper Motors. It has 1/4 elliptical springs on the front, I'll see if I can get some pix tomorrow.
    TheYeti likes this.
  13. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    It has shackles. The perches are bolted straight into axle, shackles bolted to it, and the shackles hang down to bolt to the spring. It's hard to see in the picture. You aren't the only one to say this but I assure you it has shackles.
  14. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    That would be awesome. Thank you.
  15. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    This took longer than I thought. Hope they will be useful.
    TheYeti and Spanky like this.
  16. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
  17. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    It's getting to be a big puzzle. Everything just has enough room to fit. Mocking everything up. Building motor mounts, transmission cross member and mount, master cylinder mount.
    Had to search the junkyard yesterday.. the big 130amp GM alternator was in the same place as the frame rail... no good. Found this jem from a 98-00 Honda Accord. 80 amps is plenty for this hotrod. Will make a custom upper mount but it bolts up to the factory lower bolt.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    The master is going to have solid rod running to it. I just put the tube there to see clearance. Motor mounts will have gussets.
  18. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    The master cylinder mount is gonna also double as the "landing" where the transmission crossmember meets the frame. Their will be a piece of 1/4 plate on the right side too where the crossmember lands.
  19. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Yeah, they aren’t shy about price on gauges. Hopefully your cluster is in good shape, they are known to fail. I have one in my truck that periodically acts up.
  20. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    I've replaced the stepper motors in them before. There's actually a kit produced for doing this. Hoping this ones good but I could always use one for a manual so I don't have to see the PRNDL that I'm not wiring up.
    Gotta give it the ole smack on the dash and they come back to life! Lol.
    fletcherson likes this.
Share This Page
SSL Certificate
