Welcome to Our Community
Sign Up
Dismiss Notice
The Yeti's 27 T Build
Discussion in 'Project Plans & Updates' started by TheYeti, Dec 21, 2019.
  1. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    I have a t56 that I considered using behind the 427 in my t but it’s a very big gear box... too big for mine. I opted to go with the t10 but still had fun getting the pedals and linkage to workout. Fortunately I have a flat floor so the gas pedal is sort of over the bell housing but the column splits the clutch and break pedals. I get the size 13 issue.
    TheYeti likes this.
  2. fluidfloyd
    fluidfloyd
    Expand Collapse
    Dec 29, 2008
    1,091
    290
    Gender:
    Male
    Occupation:
    Toy Builder
  3. fluidfloyd
    fluidfloyd
    Expand Collapse
    Dec 29, 2008
    1,091
    290
    Gender:
    Male
    Occupation:
    Toy Builder
    After looking at what you have I understand your problem.A far as mounting the pedal outside of the frame rail it does not offend me in the least. Narrow frames and cramped spaces sometimes dictates outside the box thinking. I had planned to do a CAD drawing but having a few computer issues so I just sketched out the basic idea. One thing I will say is when mounting cylinders low in the car I prefer using units that allow for remote reservoirs. That allows you to put them high enough to access and bleed without having to get a small child to stick under the cowl. Just a thought.
    Hope this will help you with your project. I don't remember off hand but there are some recommended pedal lengths and ratios and most companies will have that information on their websites. Hope this help you out.
    Good Luck with your project.
    George
    TheYeti and lincolnuT like this.
  4. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    Re: Pedal ratio . . . this may help. Most manual brakes will use a 6:1 ratio.
  5. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Brake
  6. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    Thank you for the info George. I really like the idea of the long rod under tension, it eliminates the sideways flex (or rainbowing) of a pushrod type. I will be sure to use this concept.
    I have to finish wiring up my door bell cameras early this week and then I'm back to T Bucket Time.
    fluidfloyd likes this.
  7. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    Im still on rear crossmember and brake stuff but heres something that keeps me coming back and re-thinking it...
    I dont like the low slung mustang box because it just doesnt fit right. It will require some block clearancing at best.. (iput shaft in the wrong spot, crowds front 4 bar heim joints)
    Is it ok to run the mustang box like this? It doesnt hang any lower and it doesnt block the exhaust ports.. no foreseeable future clearance problems. Ill make a custom pitman arm that is a smidge longer
    [​IMG]
    [​IMG]
    It will also allow me to angle the intermediate steering shaft for enough to potentially allow the brake pedal on the right side of the column possible.
    rbsWELDER likes this.
  8. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,216
    1,183
    Gender:
    Male
    Occupation:
    Retired
    I like the Unisteer rack and pinion. Several on here are mounted outside the frame. Mine is inside the frame.
    rbsWELDER and lincolnuT like this.
  9. lincolnuT
    lincolnuT
    Expand Collapse
    Mar 21, 2008
    1,825
    474
    Gender:
    Male
    Occupation:
    Retired
    The only way as far as I am concerned......I replaced the Corvair Box with this Half Rack.........I would [ut it inside the frame if I was building the car new........but this works great.................
  10. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    I am considering a rack. On the fence about it..
  11. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    Still making progress. Its suspension week.
    [​IMG]
    CheapT, James Louis and Spanky like this.
Share This Page
SSL Certificate
