I learned to do them early on, as one of my first jobs was a "mechanic" at a cab company. Brakes, tires, batteries, pumps, transmissions....dirty work, all day long. Many of the failures are due to adjusters not being correctly installed and not having the shoes adjusted tight enough initially. They also require adjustment on occasion, especially if you don't use reverse much as that's how they self adjust, or are supposed to.
The adjusters are activated by a lever (the lever that acts as a ratchet when you adjust the shoes) that spins the adjuster when the vehicle stops in reverse because of the way the shoes move. Some have a cable that activates the lever, some just secure it to one shoe. If the adjuster is installed in the wrong direction or the lever on the wrong shoe, it will loosen, not tighten and allow the shoes to back away from the drums rather than remain in contact. It's a crude, but ingenious solution, and works pretty good as long as the adjusters don't seize or the car doesn't reverse often enough to overcome the normal wear on the shoes.Fletcherson, could you please explain how going in reverse allows the brakes to self adjust? I've heard of it, but never understood it.
Oops, I replied from the initial reply, sorry for the duplicate description, I didn't see it.The adjusters are activated by a lever (the lever that acts as a ratchet when you adjust the shoes) that spins the adjuster when the vehicle stops in reverse because of the way the shoes move. Some have a cable that activates the lever, some just secure it to one shoe. If the adjuster is installed in the wrong direction or the lever on the wrong shoe, it will loosen, not tighten and allow the shoes to back away from the drums rather than remain in contact. It's a crude, but ingenious solution, and works pretty good as long as the adjusters don't seize or the car doesn't reverse often enough to overcome the normal wear on the shoes.
I agree with you 100%, Gerry!As much as I want to hold back, running a battery cable and a fuel line close together/ in the same clip, is not a good idea. Any problems with the battery cable going to ground near a fuel line is a recipe for disaster. Check out some regs for racing and see what they say about this set up.
Use the same bolt with another clamp going the other way.
I do appreciate constructive discussions.
If you are wanting a 2nd opinion, then you are ugly too!!!![]()
Best thing about these cars is you can pile up the parts and go at your own pace. My last set of Radius Rods is coming from Ron and I will have the rolling chassis (parts) sitting in my spare bedroom (LOL) minus shocks, 1 taillight, Intake & Carb, Transmission and rubber. Now maybe I can focus on saving for the body LOL. You are correct, buy what you want and don't compromise just to "get it done" . For me, that will be satisfaction.Well...... okay then... moving right along.
Good news and bad news. Good: My Speed bleeders came for the rear and are installed. Now, I can bleed the system and check for leaks. Bad: a deal on a cheap set of wheels and tires fell through.I could probably get a set, for a fee, from the salvage yard, but being on a budget, paying would be counter productive. I'll just continue to save for what I really want.
