Front wheel balancing/etc.,even if all other things are right on;this stuff can mess up ride;,
Doing this your self can be done,;
1#,jack both front up.tires off the ground right after a run long enough to warm the tires so there round,not flat spoted. check PSI so there the same.
2#pull the pads out of of cal's so tire turns free*,if it dose not turn free,check wheel bearing.
3#spin tire and check for out of round and side to side run out,about 1/8in max is still OK for ether.
4# for each tire;spin tire and let it stop by it's self,mark side of tire at bottom / lowist point so you can see your mark,check 3 times=they should all be very close=use center mark only from now on.,this lets you know were the heavy spot is,, now by moving the tire ,tell you mark is at 9:00 or 3:00 and let go of it,you will see tire mark go back to 6:00,take note of how fast it moves on it's own back to 6:00,now add a small wheel WT. to tire rim at 12:00 and test again same way as first time,it should move slower back to 6;00 or if it put your mark at 12;00 the WT. was too much. Trick is just play that game tell tire dose not really move anymore with your mark at 9;00 or 3;00.
Some of the things you find out and fix as needed are tire round[if not replace or get ture cut at a tire store///side to side run out,checks rim and or tire////balance and at the same time[as long as you don't take wheel off hub] balances brake disk also if it's off any.
If any of above are bad,all the adjustments of tow or shock mean nothing.
Rods should drive nice or it's all wasted.
