EX JUNK
Moderator
If you are like me and do not like the red and blue anodizing that comes on some aluminum fittings, here is a very good way to get rid of it. Simply get some "EASY-OFF Heavy Duty Original Oven Cleaner". Spray enough in a jar or can to cover the fitting. Allow the fitting to "soak" for a few minutes. When you extract the fitting and the anodizing is completely black, rinse in clean water and dry. Then, using a buffer, bring to a brilliant polished finished.
In the past, I have tried a lot of things to remove the red and blue anodizing but have found this to be the easiest and best way to accomplish that end.
