So it was finally time for fiberglass work, I have been dreading this task for months.  So I went to my local fiberglass shop and picked up:
2 gallons of poly resin
6 yds of 1.5 oz fiber mat
and all the tools, buckets, brushes etc etc.
I have not played with fiberglass in about 17 years (and that was a surf board repair!), so I started small with the tailgate:
I marked, cut out and taped the tailgate to the bed.  Then I laid in 3 layers of glass to attach it:
I started re-framing my trans tunnel with some chicken wire, the old setup I had was about 2 inches wider on each side then this setup.
The tunnel is made up of 4 layers of mat, I did seem to get a bunch of air pockets in the glass, mostly around the chicken wire, its not big concern and it will be covered up with paint and carpet
On the inside I laid a full floor piece, the firewall, and both sides, by then I had run out of resin......
There are not during pics as most of the time I was covered in resin and little fiberglass strands!!
So I still need to finish the back, add another 2 layers to the sides and finish the bed stretch.
Did I mention I hate fiberglass work?
