Today I spent some time making my shock mounts. I missed a few pics along the way, as it tends to happen when I am working. Anyway from my post on the shock mounts I went ahead and made up some to bolt to the batwing:
Here are the before tabs: At least I remembered this one...lol I started with 1 1/2 inch 3/16 steel. They ended up as 1 3/16 width. The left most tab was the final size before I started drilling.
Then came the task of making the upper mounts, I wanted these mount to pretty much disappear if you were looking at the car from the front. I started by pulling the shock out to 1/2 its travel. It gives me about 2 inches of travel up and down, that should be plenty.
Then I found the angle I wanted them to sit at, I wanted to top mount to be in line with the edge of the rad shell, that put the shock at about 35degrees. This is pretty close here:
Then I missed about 40 steps of heating, bending, screwing up the first attempt, heating, bending using the press instead, cutting, grinding, sanding, to end up with this:
Here it is mounted:
I still need to weld the upper piece on, but I have to hit the metal shop for the correct size tube:
Then I had to match it on the other side which is always fun trying to match the angles, after much trial error, bending, unbending, rebending, grinding....(I think you get the picture) I ended up with 2:
Now the moment you have all been waiting for! (Not really...lol)
Here is a shot from about 5 feet in front:
I could not completely hide them, but they are damn close!
Before I go any further I need to pick up some tube for the top, all I had on hand was 1 inch 1/4 wall tube, the upper and lower mounts will use 7/16 g8 bolts. So I need some smaller tubing, unless I can find some bushings to fit.
