So I finally broke down and started pulling things apart for some fixes. I need to fix a couple oil leaks, and figured while it was apart I would clean/paint the engine and trans.
So I started yesterday pulling off all the little things and today the big things. Needed another set of hands I did not have so I improvised: Engine hoist makes for a good partner:
Once the body was out of the way I started pulling the rest off. Here is where I left it for the day:
Engine and trans out. Body sitting on the floor.
Things to fix:
Oil leaks - front timing cover seal around the balancer - figured all the grinding dust ate it up.
I thought the rear main was leaking, but it turns out its the rear seal on the intake, blowing a lot of oil out, not sure how that happened. Once I tear it apart I will see what happened.
Transmission - fix o-ring on speedo sensor. Replace moderator(?) cover, its seeping through the rust, I thought it was just surface rust, turns out it was worse then I thought.
Water pump - back plate is hitting the timing cover - pull gasket off cover, use goop instead, should give me the clearance I need.
Interior - get some carpet padding, glue down trans tunnel carpet. Fix rear cover stitching, not as clean as I would like. Re-work dash - need to move gauge cluster forward a couple inches, make a new top plate for gauge cluster.
Body - clean up bad glass work on firewall, pick up some undercoating for the bottom of the body. That is the extent of the body work being done this year.
Make new mirror mounts, fix holes I drilled in the windshield posts.
Take radiator and shell to rad shop, they are going to move the filler neck to match the shell.
Pull rear-end - take to jag guy for pumpkin swap, 2.88 posi for 3.54 non-posi.
Replace rearend springs.
Make a new e-brake cable, the one I installed is a bit flimsy and I do not trust it in a panic situation.
