Keeper
So I finished mounting the brake setup today. Of course I forgot pictures along the way, so here are the results:
I mounted it as far forward as I could. The kick panel there will be made much smaller, this is only the test piece.
I have full travel with no binding and have some room to spare.
You cannot see it here, but the pedal tab there is about 1/4 proud of the kick panel there. (I took off my big work boots to check the placement!)
I mounted the unit to the frame with 3 3/8 grade 8 bolts. There is also a 5/8 bolt that runs through the frame and is used as the pedal pivot.
Only thing I have left to do is drill and tap the tube the pedal pivots on for a grease fitting. Well that and find a pedal!
