With regard to Keepers driveshaft, Ted Said "Yes I did notice that, and figure you would get my drift about it, but welding them that way will let them work a lot farther without getting in a bind, same for steering joints..."
Ted,
I don't want to hijack this thread, (That means, "here I go, hijacking this thread..."), BUT,,, I've done a ton of driveshafts in my time, you know, the friend with the lathe always gets that job, and I have the lathe... Anyway, could you explain how your statement above makes sense. You know I love you to death, but I think you may be wrong on this one.
First, if you notice ALL factory shafts have the joints phased in alignment, not 90 degrees out. All examples in the Spicer/Dana PDF docs show the joints in phase, not 90 degrees out of phase. Also, when I shorten or build a shaft, I find it easy to keep the joints in phase because it's easy to get the alignment perfect, just place a flat metal bar along the joints flat edge, from end of the shaft to the other end joint (Over the flat end of the cup surface.). Judging 90 degrees is much more difficult. Second, a given joint can only move so far before binding, (way farther than ideal for no vibration anyway), regardless of what happens at the other end of the shaft. Third, keeping the joints aligned at zero instead of 90 degrees minimizes balance issues, thus minimizes vibrations. Forth, a typical joint cross has the pivots (cups) all aligned on the same plane, so phasing the shaft 90 out won't provide any additional angle overall. Lastly, if you want bigger angles on the joint, they make special joints where the cross is offset for that purpose, or better yet, go to a CV or rubber puck type joint. (Those offset joints are a vibration waiting to happen when installed backwards or 90 degrees out of phase.)
After having said all that, as you well know, max joint angle should never be aproached in a good design anyway, and certainly won't be in a T bucket. Perhaps I misunderstood what you said/meant, after all, like you I'm an old fart with CRS! Please correct me if that is the case...
:soapbox:
Stepping down now,
Corley
OH, Keeper, looking good!
