old round fart
Yep! Take off the body and turn it over!
You can if you have a sharp hack saw.That is a good question. Can you drop the transmission in a T Bucket wit a welded in cross member?
About 15,000!What kind of RPM did you need to see 550 HP?
<bites tongue>What kind of RPM did you need to see 550 HP?
Let the record reflect I am still biting my tongue. Snickering, to be sure, but still biting my tongue.About 15,000!
You need some good flowing heads with some good old fashioned 2.050 intakes.What kind of RPM did you need to see 550 HP?
Heres a little info for ya, and this is with 1 carb, to boot....enjoyWhat kind of RPM did you need to see 550 HP?
hahaha....I look like that every morning....scarey, till my 1st pot of coffee!I've just received a FAX from Skeptical Hippo, with a suggestion that we need a new rule around here - If thou cannot produce thine dyno sheets, thou shalt not make unsupported horsepower claims.
Personally, I have found that horsepower claims are inversely proportional to the availability of dyno sheets. I'm jus' sayin'. Seeing is believing.
I'm betting that if you can find the flow numbers your cylinder head porter recorded, when he was finished with your heads and intake, you will find your dyno sheets very close at hand.
Last paragraph.
