Screaming Metal
Oh....and the 334 strokers....
Thanks for the info.
I have about settled on the 2600 stall in Speedway . since my cam has a range of 1200 to 5400. this engine is not that hot. It has TPI heads (double Captain Bars) although they are reworked with 2.02" valves. At 5400 max do I really need balloon plate at 5400?
Bucket man,
I ended up getting a Hughes GM25HD. Mainly because it had a hardened Sprag, I believe. It is doing the job, made a rubber burning machine out of it.
It still pulls pretty hard at a stop light at 750 rpm. I have come to believe the that is a product of disc brakes that are not power assisted.
Out of curiosity, why are you idling at 750? Does it still pull at say 625-650? Or are you talking about cold idle?Bucket man,
Bucket man,
I personally like them much lower at idle. At 1000, it is engaging the converter and would explain the pulling. I am not familiar with your engine, but it should be able to idle at a lower rpm. What cam is in it? If it isn't real radical, look at timing and vacuum issues if it won't idle down. Jmo.It seems happy at 750. I guess I need some quality time with my vacuum gauge as see I if I can get a little lower. It is 1000 in neutral hot/750 in gear.
That sounds like a fairly mild cam. It should be able to idle low. If all is healthy, should just take some tuning. Maybe a re jet and or power valve if it is too lean or rich. I would aim to have it idle hot no load at around 650 and see how it acts. If it won't idle there, something is not quite right.My cam is 229 Intake/230 Exhaust (@.050), lift is .486. I am running a 600 cfm Holley.
Could be, it is possible to get them to the point of not pulling to were they will require acceleration to engage, but it requires low no load idle. Idling in gear infers the engine is under load because the converter is beginning to engage. If it idled at 650 or so in neutral, it shouldn't pull when in gear, or very little. What stops it from idling low in neutral? I assume you have worked through the carb adjustments.I just went out for a 30 mile ride and kept setting down the idle at stops. Got it at 650 - 675 hot in gear. Pull abut the same. I really thing I have just become accustomed to power disc brakes. I remember I had a 69 Barracuda with no power disc brakes and it took a lot of pedal effort.
My interpretation is subject to my perception of the post, you have the benefit of feeling it. The light weight is a factor, but you should not have to fight to hold it at a light.Could be, it is possible to get them to the point of not pulling to were they will require acceleration to engage, but it requires low no load idle. Idling in gear infers the engine is under load because the converter is beginning to engage. If it idled at 650 or so in neutral, it shouldn't pull when in gear, or very little. What stops it from idling low in neutral? I assume you have worked through the carb adjustments.
As long as it puts a smile on your face! I am too big for mine too, at least to be comfortable. If you are ok with it, it's good, but if you want to minimize it, the idle should help.I don't have to "fight it" at a light. One other aspect is my size and the angle of my leg/foot on the brake pedal compared to say my truck. I am satisfied with the way it is working.
On a side note, Although I'm not an expert on the torque converter/stall speed I think it is at 2400 rpm on this car. Flash Stall. When you punch it , it jumps to 2400 and stays there till the car catches up.(nano seconds). best I can tell. I'm usually busy at this point with fishtailing and rubber burning.
