Oh, your probably about 200-250 horse range, good tuned 350, a c4b, 600 cfm 4bbl, RV cam, headers fresh motor with valvejob, sealed rings, etc.... Tuning could get you to about 27o....Not sure on the HP. But it is a 350 bore 30over - RV cam. Th400 trans. Jag rear with 2.88 gears.
About 1000-1100 rpm at idleI always wonder about this topic. Because even with my new 350sbc, which is mildly built, I have a stock converter and don't have to stand on the brake at a stop light. What are you guys idleing at when at a stop light? I'm at 750-800 rpm.
Again it will be a bunch more fun with a 3000 trust me.
Probably because that is all they have. Call TCI and see what they say.Spirit said 2400.
Just got off the phone with a speedway tech. He asked about my engine, trans, cam, rear end, and rear tire size.
Then he said I should go with a 2200-2600.
My wife's T is about 1900 lbs., stock 327, all drum brakes and I just switched that from a 2400 rpm stall converter to a 3200 rpm stall. She is much happier at stop lights.
What Screamin' said. Light bucket, go higher in slip. The converter is a strange beast that responds to the inertia of the load. A low intertia low friction load like a 1500lb bucket will not slip anything like a 3200lb Nova. JM2CW, I'd go for the 3200rpm every time in a bucket even with a mild engine.oino, converters are strange animals. Those numbers are mysterious, to a point. Put that stock converter in a 3200 pound car, its not hard to hold at a redlight, in a bucket, you gotta stand on the brakes sometimes. Also, depends on motor characteristics....wether you have a ton of low end torque or not....
One thing nice about this board, theres so many different cars with so many diff. setups, you can find just about anything you need.
Just add a cooler, though your not slipping with 32oo#'s of Camaro or Chevelle there, theres still heat buildup!
