I can't get the photos to load from my phone so I will add them later when I have access to my computer.
I made some progress on the friction shocks today. The part that attaches to the frame is made of 2x3 unequal angle iron. It will be bolted to the frame with the headlights. I still need to trim down this mount that is sticking beyond the frame. The material in-between the shock arms are discs that I cut out of a sheet of UHMW plastic. This material had less static friction so it will result in a smoother operation. The slant six valve spring keeps pressure on the discs even if they start to wear down. This will still require regular checks with a torque wrench. Thanks to @Charrlie_S from another site for sending me the valve spring retainers. They work perfect as a washer for the nut to rest on and keep the spring centered. My buddy will weld a tab onto the leaf spring shackle and the heim joint shock links will attach there. I will probably add some speed holes to the shock arms later on.
Parts are available. Chances are the throttle plate is egg shaped as well.Finally got the new intakes on the car and the carb hooked up only to discover the carb has a leak in the throttle shaft. I figured i would have a go at adding some bronze bushings to the carb body to fix the problem but when I took apart the base plate I found the throttle shaft was heavily worn and i could feel the edge where it was worn down. Found someone on another forum that has another Holley 2280 so i may get that one and swap the rebuild kit over. Or if the throttle shaft and base plate look good i may just switch them over to the carb i have.
Thanks! This was my first time. I just kept refolding the corner and trimmed a little excess fabric off each time till i got the corners how I wanted them to lay. It was fun figuring it out.Nice work! ...... Wish I could do upholstery.
I sure would like to come see you next winter if the Universe + the moons and stars align !!!Rick, I am still learning how to sew stuff up. Here is the seat that I did for the Econoline project. Almost done now and all that is left is the carpet.
