Welcome to Our Community
Sign Up
Dismiss Notice
The T in my head, thoughts?
Discussion in 'Project Plans & Updates' started by Mykk, Jul 2, 2018.
  1. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    Posted by Mykk on fb: "Started making my own set of Zoomies. 304 stainles 2.25" 84 degree mandrel J-bends.
    Super stoked to finish welding them together and terrorize the streets."
    rubicon and Snicklefritz like this.
  2. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,216
    1,183
    Gender:
    Male
    Occupation:
    Retired
    How does the EFI work with zoomies?
  3. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    Mykk posted a really neat video of his test drive with the zoomies on fb; I hope he'll post it here . . . :rolleyes:
  4. Mykk
    Mykk
    Expand Collapse
    May 23, 2018
    150
    233
    Gender:
    Male
    Occupation:
    Musician
    The video Spanky was referring too:
    The wideband O2 sensor is not working well in the current config. I need to come up with a plan B. I'm considering running the engine, seeing which tube gets hottest with a thermo gun and mounting the O2 bung in that cylinders tube so as the EFI is reading the leanest cylinder at all time. It's not ideal, but better then nothing.
  5. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,216
    1,183
    Gender:
    Male
    Occupation:
    Retired
    Can you use thermocouple sensors instead of O2 sensors? I think there would be programing involved but it seems you get same outcome.
  6. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    rbsWELDER, lincolnuT and choppedtop like this.
  7. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    I'm happy for you Mykk. Sounds strong.
    rbsWELDER likes this.
  8. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    Mykk, you've definitely got the right sound with those zoomies. Much better than the old system! :thumbsup:
  9. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,216
    1,183
    Gender:
    Male
    Occupation:
    Retired
    Mykk, do you have any baffles in your zoomies?
  10. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    I only have one sensor. Its in the no 8 tube as recommended by Kinsler. I also made a cover for the sensor to 'tidy' it up. Got to put a small slot in the top and bottom to allow air movement as its need to know the ambient air condition as well as the exhaust gas.
    o2 sensor cover (16) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG
    o2 sensor cover (13) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG
    o2 sensor2 (4) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG
    o2 sensor cover (1) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG
    James Louis, lincolnuT and Spanky like this.
  11. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,216
    1,183
    Gender:
    Male
    Occupation:
    Retired
    Gerry, where did you put the sensor? Cole’s to the head or the exit? I want to run Holley Sniper and wonder if that sensor would work for me. Guess I need to ask Holley. Lol
  12. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    Apologies. I had brain fade and said #8 pipe. I meant #2. Dohhhh
    After reading it up and deciding that it was OK to put it at, or less than 1 metre from the port. The info also said to make sure there is enough pipe on the downstream side to eliminate back flow of air and gasses to stop false reading sfrom exhaust gas being diluted with clean air.
    I put it as close to the body as I could to try and hide it a little and reduce to length of the wire to its minimum.
    Spanky likes this.
  13. Mykk
    Mykk
    Expand Collapse
    May 23, 2018
    150
    233
    Gender:
    Male
    Occupation:
    Musician
    Thank you, it's not fully tuned yet so there is still some more oomph to be had. I should probably lay off the throttle until I can finish tuning, but I can't help myself.
    Thank you, I agree. The look is way better, it is way louder for sure.
    Yes, I've been experimenting with washer "lollipop" baffles at different pipe depths to see if I can shape the tone just a bit. It doesn't really lower the dB much but it seems to shape the resonant frequency of the pipes. With the baffles deeper in the pipes you get more boom, can hear the pipe diameter and even sounds a bit flappy.
    With the baffles moved out towards the end of the pipes the resonance frequency shifts to a higher pitch, some of boom disappears. But so does some of the flap sound. It has more a nitro sound (to my ears) and is a bit more controlled sounding.
    From my experiments the sweet spot on this set up is around 3" pipe depth from the outlets. It still has some boom, slightly flappy at idle but almost sounds slightly chambered at cruise.
    In the video clip that Spanky shared above, the idle and rev at the beginning of the clip is a 3" baffle depth. The driving around down clips are with a 2" baffle depth. Not physically much difference but a big noticeable difference in sound.
    For the long term I have set of motorcycle lollipops known commercially as the DK Thunder Torque Inserts to replace my temporary washers welded to coat hanger wire. Again, it doesn't do much for dB but definitely shapes the frequencies. However the "Back pressure" or "Anti-reversion" or whatever is going on with the restriction is absolutely helping the low rpm response, cruise rpm torque and throttle response.
    Spanky likes this.
  14. Mykk
    Mykk
    Expand Collapse
    May 23, 2018
    150
    233
    Gender:
    Male
    Occupation:
    Musician
    I'm really glad to hear that as that was my plan for the O2 too
  15. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    See my above post, (couple up) because I used #2....not #8 plus some info on placement that may help.
    but I think Kinsler said #8 would be the choice for only one sensor. Of course they initially said to use 8, one in each tube, bu understood my DEEP concerns with looks for the Fad.
  16. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,216
    1,183
    Gender:
    Male
    Occupation:
    Retired
    Mykk any info as to how you are moving the baffles and such would be greatly appreciated. I’m really interested in your process.
  17. Mykk
    Mykk
    Expand Collapse
    May 23, 2018
    150
    233
    Gender:
    Male
    Occupation:
    Musician
    Now keep in mind these are temporary just find the depth that seems to be the best compromise of sounds. Once I'm set on a baffle depth I'll drill the holes in the pipes for the DK TTI's
    [​IMG]
    [​IMG]
    Spanky likes this.
  18. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,216
    1,183
    Gender:
    Male
    Occupation:
    Retired
    Thanks! That is totally slick! I love that idea. Thanks Mykonos!
  19. Mykk
    Mykk
    Expand Collapse
    May 23, 2018
    150
    233
    Gender:
    Male
    Occupation:
    Musician
    A big day for me and my project today, this morning was the inspection at the Arizona MVD (DMV) to get assigned a VIN #, and thus it's registration. Previously I was out on the road with 3 day passes using the frames serial #. Because I had Manufacturer Specified Origin (MSO) certificates from Speedway motors for both the frame and the body the MVD treated them as a 'bill of sale' so the inspection was knocked down from a Level III to a level II. Not only was the inspection easier they actually titled the car as a 1923 model year because the MSO from speedway stated a "23 T" for a brand new aftermarket frame and fiberglass body. Now I get to use a cool looking Copper Vintage license plate in Arizona. And I guess my car is now legally a 1923 Special Construction. Once Hagerty approves the insurance, I'll be good to go.
    #419 Mykk, Jan 11, 2022
    rbsWELDER, Indycars and Spanky like this.
  20. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    In Missouri, the Highway Patrol not only inspects the car, but they attach the assigned VIN with special rivets, featuring a small outline of the state's shape (hard to see in the picture.)
    rbsWELDER and lincolnuT like this.
Share This Page
SSL Certificate
