Don't over look the Ford 8.8" axles in your posi search...a lot of width, ratio and brake combinations out there for good prices (if you stay away from the Mustang units). I got an 88 T-bird turbo coupe 8.8" with a 3.73 ratio and disc brakes for $100.
Uhhh, 3.73 , 28" tires= 3000 rpm @67 mph....
YOU said...3.73--3700 rpm----60 mph ...I simply pointed out that your state numbers were incorrect....or embellished for dramatic effect
I personally couldn't care less how fast you drive....
Well it all depends on your trany and gear ratio as well, say with no overdrive?
I have a 2 speed powerglide, I think first is 1.8 and second is 1:1.
Or maybe you guys are just calculating 1:1
Think about a 700r4 with a 3.73 or 4.10 gear. the 700 has a real low first gear 3.06 I think and a .6 OD I think. To tired to go double check.I'm looking at an over drive as a possibility. See, when I had my T, I drove everyday, weather permitting. 40...50 miles, just for fun. On a good weekend a few 100 miles. Yea.... a few HUNDRED. I don't wait for weekends to drive around. So, I figure a 3:42 would be less of a strain, in the long haul. Hell, maybe I'm wrong, but as always, there's only one REAL way to know for sure.
As for missing the "zippy" between stop lights, the power to weight ratio of these cars is a great equalizer. I probably won't even notice.
Zandoz, I had been considering the 8.8 posi and I was going to go for it, but pinion the off set and prices here just kinda talked me out of it. Prices in Houston are stupid. $450 to $600 at a junk yard. Everybody wants one. As I stated earlier, a 3:73 was a lot of fun, stop light to stop light, but I was turning 3,700 rpms at about 60 mph on an open stretch. It sucked.
Bill, you won't have any loss of power with a v6 if it's healthy. We used to put them in all kind of things from Toyota trucks to diesel Mercedes with bad engines back in the late '80's. They are easily capable of 200-250 hp with mild upgrades.,with a decent gear, that thing will be a sleeper!The pinion offset varies depending on what model it comes from. The T-bird unit I have has a 0.56" pinion offset. If the 3.73 is too revy, the manual trans Turbo Coupe axle is 3.55...other models vary from 2.somethings to 4.10 or so. At least around here the $450-$600 prices are typical for Mustang and full size truck units. When I was looking Ranger/Explorer unit were around $250 and Crown Vic disc brake non-ABS units were $100-$300.
The axle ratio for my car was a subject of some debate for me. My bucket will by no stretch of the imagination be a speed demon. In fact it will be a casual cruiser that will suffer from IBMS...Itty Bitty Motor Syndrome. It's expressway/interstate miles and time over 60 mph will be minimal. 2 facts sealed the decision for the 3.73. First, the car my engine & transmission came from had a 3:23 ratio axle, but was close to double the weight...and was still capable of typical day to day driving. Two, the most fun car I've driven was about the same weight as the bucket should be, but only had about 2/3s the horsepower and 65 MPH was probably as fast as was mechanically comfortable....what made it fun besides the handling was that it was geared to be ABSURDLY quick. What it boiled down to is that for me being quick is more fun than being fast. With a 3.23 ratio the engine and transmission were capable of propelling a vehicle with double the weight to horsepower ratio on the street/road situations that will be typical for me, so I figured I had some gearing room to pick up a bit of quickness.
The weight of the car is going to offset the radio difference imho. The cam selection is or should be a consideration, but for a cruiser with a mild small block the 342 is a good gear. I had one in my iroc with a 700r4 and it was quick as hell. You will be at least a third lighter. We need to coordinate shipping with someone, we could make some cash on rearends, they are about half that around here. There is nothing wrong with a ten bolt rearend. I have punished them and they do fine. Not my first choise, but very fitting for your intent. If you haven't yet ordered from macs, order some trivial stuff to get on their email list, then they send discounts about every week. They have some cool stuf, not cheap, but hard to find stuff. They are part of a company that bought out several similar type business, so it's sort of like a monopoly, prices fixed... Seems to be the way of the world. Bad for us...
When I FINALLY made up my mind to build a cruiser, I called the guy building my engine. He hadn't ordered any internal parts, so he threw the list away and made a list of parts for a nice cruiser with a bit of spunk. He says it'll be almost like my last engine. So, with that taken care of, my search for a S10 rear began. I no longer needed a 9" and a S10 was a money saver. I punished the last one and it never failed. Never even hinted that something could be wrong. So, for this time around, which I really hope is my last time around, I want a car that's going to look nice, perform well and be dependable.
In a world of terms and niches, I guess I'm building a "Street Rod", instead of a "Hot Rod". And I'm cool with that. In younger days, I had FAST cars and life was grand. I fixed them during the week and broke them on the weekends. But as I creep up in age, I find myself enjoying nice long drives. Tearing apart a Hot Rod every other month is no longer fun, like it used to be.
What motor is it? A 4.3 is rated a 220, I have a older mercruiser branded 4.3 that is advertised at 235, its carbureted with a Rochester 2 v with hei ignition andWith the old GM iron head 60° V6s 200-250hp would take some serious mods...,and mine will be minimal mods. Basically just manifold, carb, distributor, and headers...and most of that is for eliminating the electronics spaghetti nightmare, not for performance. I'll be surprised if it hits 150 hp. With a V6 variant of the 700R4, the 3.73 rear end, and 28"-29" rear tires I'm hoping it will be a fun casual cruiser.
150 hp in a 1800 pound buggy will move ok. I thought you had a 4.3... Those are what we used to swap into stuff that a v8 wouldn't fit or wasn't wanted. I think those little v6's were rated for around 125 or so. Carb and ignition is about all I would do. If you wanted more, a different engine would be more money wise than upgrading it.With the old GM iron head 60° V6s 200-250hp would take some serious mods...,and mine will be minimal mods. Basically just manifold, carb, distributor, and headers...and most of that is for eliminating the electronics spaghetti nightmare, not for performance. I'll be surprised if it hits 150 hp. With a V6 variant of the 700R4, the 3.73 rear end, and 28"-29" rear tires I'm hoping it will be a fun casual cruiser.
