Good to have you back Fred. You should be rested and ready to get at it!
Look close at the rod ends for clearance at the ends. You may need a cone spacer. Speedway has them.
I don't understand putting the heim balls at such an extreme angle. Wouldn't putting the rear end brackets at an angle be a better way to go ? Perhaps other members could clue me in.
John
Respect for leaving the laptop behind you for a couple of weeks.
One thing about stick welds is they dont mind being ground out and another bead being out on top. Learned that 40 odd years ago from a guy that could weld spaghetti to wood.
Only one comment on the hemis. Some sort of safety washer (which I know you know about). I had these made to do it all in one.
Damn Gerry, those are nice! I've been looking for something just like that.
Mmm. I had these made for me. Had to pay for a spark eroding tool for the "torx" type drive socket, as the company Torx would not give us the dimensions becuase they are a trade secret??. We did out own version of a 6 star drive. Then the bottom side was designed to mimic the top with the same 6 star drive. No need for washers as the heads cover the Hemi balls, should they pop out.
They were CNC'd and then spark eroded (old style threads to boot. 1/2" UNC). Problem is they worked out a 50 bucks a piece and I have 16 on the T. I know its a lot of money and most people will not see them but I have to say I smile every time I look at them. The tapered heads reflect the tapers that are everywhere on the T.
Dont see anything wrong with the welds; just a plus for stick welding that makes me use it when I can.
Ah found the pic.
G
Yep, loads of pics but I don't want to hijack your thread.
