I have pondered the use of clevis pins also, seems to me a solid mount point (I get it, y'all use clevis pins) would somewhat bind the suspension. I chalked it up to they have been doing it on t buckets forever. The car in my avatar is a dirt modified, we use heims throughout the entire suspension, 90% of which are single shear. We have taken 80 mph direct hits to the suspension and I have yet to see a heim end fail. I have seen them bent into the shape of a j and stay intact with the RR, and I have also seen the RR snap in two and the heim is still connected to the mount point and RR. Suffice it to say I doubt I would have any misgivings about using heims on a single shear on a car this light, providing that the mounts are solid and well gusseted, given they can take the abuse on a dirt track with a 2300 lb car throwing alot more stress at it than any road (well maybe not our PA roads lol) As was mentioned though, make sure you use a containment washer out the outboard side of the heim.......
Maybe it was used because, frankly, a clevis is purdier than a heim?Thanks, that's what I found. In a lot of racing applications a rigid mount on a suspension is ridiculous. IMO, from what I've found, clevis pins are a cheap form of security. Over the last 30 years, technology has advanced on Heim's and the mention of a 2 movement "clevis PIN" is crazy at best and antiquated . The numbers are there. Folks just have to "Google it".
These little jems here will prevent binding the body of the heim against the mount. You may or may not need them. A-1 RACING PRODUCTS INC.
Weld it up, I am sure you will do just fine.So, I got off my lazy ass and fixed the ARC welder. Then, I tacked in some of the brackets I had. I must admit, I had forgotten how much I enjoy welding. The temptation to weld everything solid was strong.
Is that a Speedway pedal assembly? It looks like one, but it also seems like the pedal arm sits farther out from the frame rail than they claim.
Fred: What happened to our girlfriend in the avatar??
Hell yea, weld er up! Make sure you have it how you want it. You can always cut em off if you have to, not the preferred method, lol! Truth be told, every welder fabricator has a supply of cut off wheels to erase and start over!... I actually like to stick weld and torch braze best of all methods. Probably because that was the first and most prominent type that I have done. There is something about the smell, sound, and feel of melting steel with a rod.
