tfeverfred
I checked out the QA1 Adjustable shocks I had used on my last build and they will give what I want. Mounted length is 14" with a 12" spring rated at 175lbs.. They're a little higher in cost, but they were worth it.
How hard would it be to replace the rear crossmember with one of the stepped back ones typically used for Model As to get axle clearance?
http://welderseries.com/blog/#!/Model-A-Rear-Crossmember/p/50878748/category=12959479
If I wasn't set on how my car will look or if I hadn't bought the panhard bar, that would have been a nice option. What I have planned will work. It's just not what I originally envisioned. I should have specified longer rear rails, when I had Ron build my frame, then I could have gone with a Watt's linkage, which is 10 times better than a panhard. But I wanted a shorter looking frame for my build theme, so I'm making concessions where I have to in order for it to work out.
If my posts read like I was disappointed, I'm not. I'm just logging the ups, downs and speed bumps involved with my build. The cool thing about building anything from basically nothing, is that you have the freedom to make changes when needed.
That is kind of like why my build is taking so long to get started. I keep changing the design. I guess I just need to start and let the things fall where the May.
How much interference are we talking about? Can you cut the front bracket off put a spacer bushing on the back one and reposition the front one?
How about using the forward bracket and welding a new one forward of it and the rear bracket for your tail light?
Cruising along Fred, looking good, I plan on 37' taillights also, they are a close match to my headlights
They remind me of your avatar for some reason lolI just dig the streamlined shape. I hope I can adapt them.
