tfeverfred
New parts coming soon...........
Remember the rod goes up when the rear goes up. Take the shock loose and go through suspension travel and check it out.
 I took the shocks loose and the rod was level. But I also noticed I have quite a bit of the rod ends out of the rod. It looks like I either need a longer rod or remove the axle mount and move it in more. I'll get with Ron about cutting me a longer rod. I'd rather do that, than cut out and redo the weld what I have now.
 I took the shocks loose and the rod was level. But I also noticed I have quite a bit of the rod ends out of the rod. It looks like I either need a longer rod or remove the axle mount and move it in more. I'll get with Ron about cutting me a longer rod. I'd rather do that, than cut out and redo the weld what I have now.Wheels and tires shouldn't affect panhard angle, they do not change the relationship of the axle to the frame, but shocks will. Depending on where they settle with weight on them. The j-bar looks like a good option or a taller mount on the rear. You want the panhard as close to level at ride height as possible.
J-bar will give you clearance but will not change the operational angle of panhard bar. The arc of the panhard bar is prescribed by a straight line through the pivot points of the bar, not the shape of the bar. We always say the "panhard bar should be level" when we should say that the pivot points should be level. This gives an equal amount of sagitta in both directions of vertical axle movement.
Does the slight difference with mounts not level matter?? Open for debate and subject to intended purpose of car. Calculations are easy for those with inquiring minds.
I agree, the panhard has more to do with the roll center so if you aint racing it I doubt it is that big of a deal. I think its more about aesthetics in these cars (keeping the rear centered/appearance from the rear view) or "fit over function"Thanks, Mountainman. I did some measuring tonight and my earlier concerns were premature and have been addressed. A J Bar, as you stated, would not change the fact that the desired setting is a straight line through the pivot points of the mounts. I should be fine with my set up.
Cool find Fred! Just use the same brackets with your measurements and you have a spare rear end just in case!
That's a sweet deal Fred, I got about 900 bones in my 3rd member!More info and a clarification on that 9" rear end. It is NOT a Trac-Loc. But it has an after market posi and the gear ratio is 3:25. He told me, that's a nice street gear for a T Bucket and he's owned quite a few. So, I'll take his word for it. Plans are still the same, it'll be a side project. So, I started a "curse jar" to save money for it. It's got about $25 in it, so far.
