old round fart
A 383 will be scary in a bucket Fred. That will be just enough. You don't HAVE to use the whole pedal.......unless your behind! Lol
Have you had / driven a T-bucket with a converter that had only 2200 rpm stall speed and a fairly large displacement engine? It might want to creep at stop lights.
You da man!
Naw, oil will be clean as a whistle and pressure marks spot on.
You and I are afflicted with the same desese. Champlain taste and beer pocketbook. Lol
Not sure what that means or is referencing, so......
Fred,
I'm in the same boat as you on the engine size. Mine is a remanufactured stock 350. I've driven a tbucket with a 383 and it seemed way to easy to get into trouble with. I mean I like having fun as much as the next person, but there is a time and a place for everything.
I'm so close to seeing if MI e will move under it's own power it is silly. I remember you taking me around the block in your car and the bobody wasn't tightened up to the frame. That is where I'm at on mine.
Im order g some washers like the ones you have for the heims. Thanks for posting g that.
Yours is coming along too.
Later
PaulR
That when you take off the old cover there is no contamination in the oil and the teeth are good to go.....
Fred,
I may have to talk to your engine guy. I like the torque number. I did like to replace the stock cam with something that has a noticeable lumpy idle. Nothing drastic.
After I drive it for a while and work out any issues that come up I'll have the body/bed painted and upgrade the engine. A winter project. A Houston winter project....ha ha.
PaulR
