NorthernILtbucket
When it comes to figuring out what stall converter is best I am at a total loss. I have the 383/TH350 combination with moderate rear end gearing using stock Lincoln Versailles gearing. It wants to stall at the stop light and idles nicely at about 1000 rpm in neutral. Air fuel mixture is set for best vacuum while in gear on the two 450 holley's. Timing is advanced about 12 deg. It currently cruises nicely at most speeds. Sputters just a bit at initial acceleration. As far as I can tell it now has the stock converter.
Does a 3000-3500 stall sound reasonable when I go to replace? It seems to be somewhat common for the T,s with this engine trans combo. The whole total weight thing seems to be throwing people I ask for suggestions. Thought I would ask the guys who have the light weight cars and have dealt with this before as internet searches return many different suggestions.
