Island Girl
Are they on the engine or on the shelf, cannot tell from your comment for sure?
Do you know how to check by rolling the rear tire one revolution and counting the driveshaft
revs? If it's a limited slip diff, that will make a difference in how you count.
Ok, then why are you idling at a 1000 rpm, should be around 600 to 750 rpm? I'm confused!
Why not call 3-4 TC companies and see what they say. Don't tell them anything about what
the others have recommended. Take an average of those 3-4 companies. Check out their
websites and see what questions they are going to ask. They usually have a form you can
fill out.
That might be worth a try, but about the 1st, (or maybe 2nd) thing they want to know is cam duration at .050", which he doesn't know.
The tech guys don't usually want to offer much advice if you can't tell them that.
Idling at 1000 in neutral is probably what it takes to keep it from stalling when it goes into gear, which if so, definitely indicates a higher stall is in order.
