AndyMenon
Hello,
Here is my distributor wiring set up. I need to confirm where the 2 pink wires from the harness go on the Ignition switch. From what I understand, the coil has to be energized when the ignition switch is turned to the IGN position. But when the motor fires up, and the ignition switch returns back to ACC position, how does the coil continue to remain energized? I have the sketch below.
thanks,
Andy
![Coil.wiring.png Coil.wiring.png](https://tbucketeer.com/data/attachments/2/2943-50bfbcd61ec350e202234015ff7a83f0.jpg)
thanks,
Andy
