AndyMenon
Best practice to have only one wire per terminator (i.e. crimp lug, spade terminal etc.) so you can isolate individual circuits in the future. Distribution block doesn't have to be right there at the switch, can be somewhere else handy. Keep in mind if you run everything from the ACC terminal (which is a good idea, as Potvinguy says), you could well exceed the current rating of the switch, in which case a relay (which you already know about) is indicated.
BTW most ignition coils generate a bit of heat and its a good idea to mount them somewhere well ventilated, or even out in the breeze. As a general rule, keeping the High Tension (high voltage) leads as short as possible is also a good rule, especially the HT from the coil to the distributor. You might consider re locating the ignition coil, which will free up space for the ACC relay and terminal block thereof. JM2CW
Thanks WM. My ignition coil is not the conventional round coil. Rather it's a bevelled shape.
This is how my wires are laid out:
- My intention of putting the coil under the dash was to reduce the length of the wire leading to the coil positive from the fuse block. (Besides, mounting a coil of this shape on the firewall competely ruins the look of the tub).
- Also, the panel under the dash has been filled with relays is because I wanted them as close as possible to the appliances they are used on (in my case the HI/LO Beams, the Electric Fan, Electric Water pump, Oogah Horn).
- The relay for the fuel pump is mounted under the seat so that it can be as close to the pump mounted in the middle and below the gas tank.
- Most positive wires run from the fuse block, down the right side edge of the tub, on the inside to the battery to minimize the length and keep them away from the fuel line, (and also, makes it easier to deal with the wires if I have to lift the body because all i got to do is detach them from the battery positive without having to pull them into the body if they were running on the frame rail).
- Almost all ground wires for the appliances run on the driver side frame rail, to an absolute grounding point on the driver's side kickup and do not have to be touched, should the body need to be lifted from the frame. Did not want any guesswork as far as ground wires go.
Andy
