I'm not sure I can talk intelligently about your question specifically. But I do wonder about a
few other things that maybe you have not considered ???
- Are you sure it's a 4L60e or 4L60 / 700-R4. The first one is electronic and the 2nd one is not, but they are the same essentially otherwise.
- You will have to change the trans mount and driveshaft for the 4L60E/700-4R. The driveshaft will have to be about 3 inches shorter.
- Have you considered the 200-4R, it's the same length as the TH350. You can use your old driveshaft, but the trans mount will have to be relocated
- The 200-4R has better gear ratios than the 700-R4. The jump from 1st to 2nd has a much larger RPM drop on the 700-R4. See graphic below.
- The 200-4R has a better OD ratio of .67 compared to .7 for the 700-R4.
- The 700-R4 was produced in higher quantities and is easier to find parts for.
But there are shops that carry parts for the 200-4R.
Precision Automatic Transmissions & Internal Components | GM | Ford | Street | Race | Custom | Retrofit
TurboBuickPerformance.com
Disclaimer: I have the 200-4R and love it.
I bought all the 200-4R transmission and parts that a transmission shop had when they went out of
business. Then I cleaned it, dipped it ATF, bagged, and labeled it according to the ATSG manuals. I
even have a couple of New Old Stock items.
OK, I will shut-up now unless you ask some questions.
