Not as difficult as I thought it would be. It only goes together one way. lol. Could have used a good th350 bushing driver. But a complete kit is like $300. I do have inside micrometer gages, so a few bushings that I didn't have the right size driver for, checked out in tolerance, but I did get the most important ones. I ended up with .017 end play on the input shaft. Have all new seals, red Alto frictions, new steels, thrust washers, Torrington bearings, and I ordered a new heat treated outer race for the intermediate over run clutch. Supposed to be the weakest link on the th350. It might be overkill for a pretty much stock engine, but I might not leave it stock. Also installed a B&M street shift kit. I don't think I needed HD with such a lite vehicle, and I doubt I'll be doing any towing.
Since I found so much wrong with this "running transmission" I'm thinking it might be a good idea to go ahead and tear the engine down and do a little inspection to see if it needs to be rebuilt.
The transmission will get me home, or anywhere else I might want to go, with out fail. As long as I don't rip off the pan on a speed bump.
