My build
I'm gathering parts for my build. I plan on building a T Bucket low to the ground. So here's the list of part I have at this point. RPM body, 29 Model A rear to be converted to 9 axle and yoke ,Model T fuel tank, sprint car box and a ford 2.3 4 banger set up for mild mini stock racing spec apox 250 hp.
Jim don't build it to low, my car sits low and I drug my transmission pan on the fill cap where a gas station fills their tanks it started leaking and when I got under I found out I was lucky only the drain plug had been knocked loose, tightened it up and all was ok it could have been worse.
