I should of added that the car was one that Nick Conti built and was featured in a magazine I believe. It was based on the idea of building a cheap but good looking bucket. If only I could buy a hood that would fit! lol I have some ideas that involve a lot of pain staking work to build a fiberglass hood. I am thinking of asking around at local hot rod shops to see if they could form one out of sheet metal for me. Maybe a college with courses in this type of work would be interested in doing it as well. Otherwise I wonder about building it out of light ply wood using the cowl and radiator support as templates for formers and cutting light plywood to fit. Of course it would all be just a little undersized and then glassed top and bottom. Also considered buying an English wheel and trying my hand at it. May build the car with provision for the hood and do hood after car is on the road. As it stands that hood seems like a daunting task to tackle.
I have a similar quandry with the build I'm planning. In my case I'll be needing an opening or scoop in the top for the air cleaner...and the ability to shape the front to conform to the track roadster nose I'm planning on. Most of the hoods I've encountered are for '26/'27 Ts, which are of no use. But I have encountered 2 pieces that may be adaptable. The first, a fiberglass '23 style hood with a cowl induction style scoop, from Spirit... http://shop.spiritcars.com/body-fiberglass-parts/23t-cowl-hood.html The other is a 1 piece steel top only '23 style hood from Langs... https://www.modeltford.com/item/N141-23-25.aspx
Right now, there is a 3rd option I'm toying with...what I call "Spats". Two separate hood sections, separated down the center wide enough for a scoop to fit through. The two pieces should be easier to form from steel or aluminum.
