Cadillac 472 from a '68.
That should give you a ton of torque, which is the real fun-factor in these little cars!
I read that..its a super cool motor imo, were picking the block back up Tuesday from the machine shop. Also, made a little progress this weekend as well. Went and got my rear end from a buddies junkyard, a Ford 8" from and old Grenada, and a th400 tranny. Busted the rear end apart to take and get one side shortened 3 in. or so to straighten up the stump. My OCD will be on full tilt with a misaligned transverse spring and center stump. Pretty sure the driveshaft will be long enough to help the off centered pinion. Parts are ordered for the rear suspension, and should get to mocking something up in the next week or 2.
its a 2.79 gear. Trying to figure out the best ratio for my motor/tranny combo. Any thoughts or recommendations??Do you know what rear gear you have in that 8" punkin?
I'm running towel city cheater slicks, I think they are 28.5I'd say with all that torque on tap, a tall gear like 2.79 might be OK, provided you don't go too tall on the wheel/tire combo. You'll still be able to jump away from a stop light, and have a nice low cruise RPM. I have a 3.08 in mine, but my rears are only 26.5" diameter (2,350 RPM at 60mph with the 1:1 3rd gear in my TH 350).
awesome info,,I'm still trying to learn this part of the build. I got the 400 cheap, and its been rebuilt already. And to answer your question, I couldn't give a shit less about gas milage tbh lolWhat do you want the car to be good at ....... gas mileage or acceleration ??? What about using
a 4 speed automatic like a 700-R4 or a 200-4R, both made by GM.
View attachment 19347 View attachment 19348
Or you can calculate your own specific RPM using the Excel spreadsheet below. Only change
the numbers in the first 3 columns, the rest are calculated.
Well then, you will want to change that rear gear for better Gitty-Up-And-Go !!! LOL !!!And to answer your question, I couldn't give a shit less about gas milage tbh lol
I built a 200-4R with a 0.67 final drive ratio since it had the same drive shaft length as my TH350. With 31 inch rear tires and a 3.7 rear gear I only turn about 1900 RPM at 70 MPH. The later 4 speed trans have a lock-up torque convertor, that drops the rpm another 300 rpm since there is NO slip.awesome info,,I'm still trying to learn this part of the build.
The 472 is a high torque low rpm motor,,would that make much difference?I built a 200-4R with a 0.67 final drive ratio since it had the same drive shaft length as my TH350. With 31 inch rear tires and a 3.7 rear gear I only turn about 1900 RPM at 70 MPH. The later 4 speed trans have a lock-up torque convertor, that drops the rpm another 300 rpm since there is NO slip.
Your actual RPM will be higher than calculated for an automatic without a lock-up TC. All the calcs assume zero slip or a manual trans.
The car should run just fine with the 2.79 rear gear. But is it what you want or whatThe 472 is a high torque low rpm motor,,would that make much difference?
