AndyMenon
Huh. Sounds like you have flashing and ground at the buckets. Extremely unlikely that you have two bad bulbs, but this problem is with both buckets, right? Guess you need to open the buckets and check the wiring to the turn lights. Pull the bulbs and check for flashing voltage at the contacts. Somewhere you must be losing the flashing or the ground.
You're fine with just the one flasher. The rear turns work OK, right? Does the hazard switch work?
And, hello, I see a mistake in the diagram. Both the black and blue wires should go to the L terminal of the flasher. Power goes to the X terminal. Fix this and try the lights before tearing into the buckets.
OK! Nice to have a couple of days off so that I can be down in my garage in peace . The boss and the 2 lunkheads are out of the house. Yay!
Yes, the issue is with both buckets. The 2 turn signal bulbs when pulled out of the buckets work fine.
Rear Turn, Brake lights, 3rd Brake light and Hazard works perfectly. Even the third brake light flashes when the hazards are on!
I will reroute the wires as you suggested and check if that fixes the problem. It's really painful opening up the headlight buckets
Thanks much! Will keep you posted on the fix.
