1919 Chevy Bucket
pray for the big brown truck. Might want to start thinking what plan you have for the wiring maybe ron francis A quality kit but pricey.
Or the Fed-Ex guy, as he is holding my 700R4 hostage somewhere in Texas. I've used Ron's kits in the past, and made my own when using cloth covered wire...this time tho going to use a local (WA state) business.
see here: http://www.4wheelinjunkycomoffroadproducts.com/servlet/the-34/hot-rod-rat-rod/Detail
you can see its all I need for this build
Nice clean job, looks like you will have plenty of leg room by keeping the body on top of the rails. ?
Almost every T-Bucket is built with the body channeled over a rectangular frame and as my "Theme" is "Sorta like a T-Bucket only its a little different cuz its a Chevy." I decided at the outset to build it "Highboy" style so I could fit down in the car, hence the pinched rails following the body contour to give me a little more room for my butt.
Got the rear kickup fabbed and welded on over the weekend.
And Done:
I really put the heat to these and because of the amount of stress this join will see I ground them flat and will fab outside fishplates for inside/outside and bottom, with a gusset that follows the bodyline on the top.
Worked on laying out the front airspring crossmember, and will get to the rear framehorn/loop next week...
Got my Firestone 135/15's from Coker mounted up and did another mockup to measure for the air suspension this weekend.... Here are some more pics:
Where is this build now? Is it done or has it been shelved? Anyone know?
