cooters T bucket build
I laid pencil across engine bellhousing and straitedge to transfer to firewall. is this how you would do this?
I use this method to transfer shapes. Like a kid's Spirograph, an assortment of different sized washers.
Works like a charm.
Why I like this Forum! There is always someone out there who can show you a cool way to do something. I mean that washer thing is the coolest.
Truer words never spoken.:thumbsup: Well at least in the last 30 minutes. :roflmao::whistling:
What is best for cutting my firewall now? Body saw, drimmel, sawzall. I dont wanna tear my body up. Aint got plywood yet so she is thin.
From wood working experience I would use a variable speed jig saw. Both the drimmel & sawzall are difficult to control. I have battery powered jig saw that is really easy to keep on the line.
I use 1mm cutting wheels in an angle grinder to get it close. They cut glass like butter.
Then finish it off with sanding drums.
Just set up a fan and keep the rotation of the tools rotating away from you.
I have those cut off wheels and sanding drums. That what ill do. I used cut off to channel. Thanks again.
I'm mot even remotely near the time to try it out, but I've been wondering about using a RotoZip for rough cutting, then sanding drums in a cordless Dremel for fine tuning <shrug>
A RotoZip will work, but you gotta hold on for dear life. The bit wants to climb while you're pushing it along.
Welllll...scratch the RotoZip. I guess I'll probably go with a battery jig saw.
Unfortunately I'm going to have a lot of cutting to do. The previous owners of the body and track nose did a lot of very rough cutting that needs correcting...plus I'm going to have to do a door cutout.
Air - powered body saw for curves....cut--off wheels for staight ..... fine coping blades w/sawsall or jig saw work well but the blades don't last long..
